Ana içeriğe geç
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
Drivers side brake light doesn't work.
2003 grand am drivers side brake light does not work . Under hood fuse for brake lamps good, changed bulb x2. Installed new dorman tail lamp circuit board, still no light. all other lights are good, turn signal and marker lights. Right side and center brake light work fine. Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
I think that this wiring diagram is correct. Apologies if it is not.
It shows that to operate the driver's side brake lights the power comes into the light on the yellow wire from the left turn signal indicator switch contact when it is not operated. It comes into the right side light on the dark green wire from the right turn signal indicator switch contact when it is not operated. These switches are located in the turn/hazard/headlight switch assembly. Presumably this is connected to the stalk control on the steering column which controls the turn/headlight/hazard light functions.
Brake light power comes into the unit on the light blue wire, through the switch at normal, to the centre point between the left and right turn switches, splits to go through the switches at normal to go to the lights on the yellow (left turn/brake) and dark green (right turn/brake) wires. See image.
I think that the left turn switch contact at normal, (operated is OK as you say the turn indicator light works) or the connection between the left and right contacts (as the right brake light works OK) is faulty.
Apologies if you know how to read a wiring diagram
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
Your hazard light is jammed, press it in a few times, loosen it up
Puan 3
2 Yorum:
Just had to comment ! No brake lights on my 2002 Pontiac Grand Prix. Center light in back window works. Had bulbs changed and brake lights still did not work. Was getting ready to put in the shop, then found this post. Tried to push hazard button on steering wheel down and it was stuck. Tried my little girly hammer. ( I am a 68 year old grandma). No luck. Got a bigger hammer! Tapped a few times. Tried to push down, IT WORKED ! Had my sister come out and watch while I pressed on brake, VOILA !!! Brake light lit up like the 4th of July !
Thank you, Thank you, Thank you !
tarafından
2001 Pontiac Grand Prix. 3rd brake light worked, and the other two did not after all bulbs were changed out. I was getting ready to try replacing the brake switch when I found this. This was the problem and unjamming my hazard light switch was the fix! Thank you so much!
tarafından
Yorum Ekle
I had this problem when I switched tail lights to LED,, check wire connections running to bulb plugs, also my plugs were submerge in water. Stock tail light was 3/4 full.. but you may have a short, clean plugs and apply bulb greese. That was my issue.
Puan 0
Yorum Ekle
Yanıtını ekle
Tom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 6,388
