Where is the radiator fan sensor
Bu iyi bir soru mu?
rosecare1, the engine coolant temperature ( ECT) sensor is mounted in the coolant stream. The power control module (PCM) applies 5 volts to the ECT sensor signal circuit. The sensor is a thermistor which changes internal resistance as temperature changes. Your ECT sensor ( you did not give us an exact model and year) is most likely located in the water outlet housing, adjacent to where the upper radiator hose connects to the engine.
Check this video as well
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,670
1 Yorum
where is this fan sensor on 1998 cavalier
mwharris56 tarafından
