Ana içeriğe geç
Lenovo business laptop introduced in April 2011.
Why does my fan make a high pitched noise?
My computer is making a high pitched noise when running and when in sleep mode. How do I fix this?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
The high pitched noise may be due to your fans needing to be cleaned, try blowing air forwards and backwards through the fan. Another option is to shut your computer off and let it cool down. If noise continues you may need to take the computer apart to do more cleaning of the fans.
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
I had the same problem. I used a hairdryer (cold air!!!) up and down the fan outlet for about a minute, while the laptop was still one, but resting vertically on its side, and it removed the problem completely. I have seen this problem before on another laptop and cured it the same way. Don't use a hot fan!
tarafından
Yorum Ekle
En Yararlı Yanıt
You can start by cleaning the fan first by blowing air through it forward and backward . If this doesnt help then take the laptop apart and do a more through cleaning of the fan put a touch or lithium grease in the bearing . If this doesn't help you will need to replace the fan
Puan 6
Yorum Ekle
Make sure of exactly where the noise is coming from before you spend any money. It could also be the hard drive. See this video: https://support.lenovo.com/us/en/videos/...
Puan 6
Yorum Ekle
In my case it helped to carefully remove 3/4 of the round tape that sticks to the back of the fan. It holds a little brass cap that covers the fans center bearing.
I put a tiny drop of sewing machine oil on the bearing and re attached the tape with the cap. Fan works perfectly again.
Puan 0
Yorum Ekle
Yanıtını ekle
Emily Heffernan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 57
Her zaman: 27,778
