Ana içeriğe geç
Sony Xperia Z5 Android akıllı telefon Ekim 2015'te piyasaya sürüldü. Sony Xperia Z5, 5,2 inç 1080 x 1920 piksel ekrana sahiptir ve 3 GB RAM, 23 MP arka kamera ile birlikte Qualcomm Snapdragon 810 işlemciyle donatılmıştır.
How to replace the frosted glass back?
I dropped my z5 dual straight on its back and the frosted back glass has shattered. If I buy the replacement part how would I go about replacing it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Here is the video showing how to replace broken z5 back cover:
https://www.youtube.com/watch?v=FY2z27SA...
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You should check the model number first if this is a dual sim version?
You can check the model number of the Sony Xperia by using this:
Resim
You can buy the back cover from here: (It fits Sony Xperia Z5 E6603 E6653 E6633 E6683)
http://www.ebay.com.au/itm/Original-Glas...
Here's the guide on how to do it: Note that you only need to do step 1 and step 2.
Sony Xperia Z5 LCD Ekran Değişimi
Note: Please be careful because if I'm correct there may be a white NFC sticker tag on the back cover (It is a white sticker with two golden contact points). This model probably doesn't have it. If it does, you'll need to heat it up then carefully separate it from the back cover as it is held by adhesive.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
No backlight in Sony xperia z3 compact. Solución please
tarafından
Yorum Ekle
I did all those steps now nfc doesn't work. Maybe sticker not making contact with the motherboard. Do I need to buy a new sticker? And if I open the back cover again, will it remove all the glue, needing a new cover?
Puan 0
Yorum Ekle
Yanıtını ekle
Karthik Krishnan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 20,706
