Ana içeriğe geç
The KitchenAid KSB5CR is a five-speed blender manufactured in 2006 by KitchenAid. It is available in black and chrome color schemes. Repair of this device requires screwdrivers and prying tools.
5 Soru Tümünü görüntüle
Should the motor produce light?!?
Great guide!
Because the blender makes a "burnt rubber" whenever its run regardless of load, I removed the cover from the base to inspect the fan, motor, and assembly.
Seeing nothing amiss, I cradled the base (inverted) and "pulsed" the blender. For every pulse, there was a flash of bright light. It was white, not orange.
Is this normal? Could this be arcing? That might explain the "burning" smell.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@engineer that will depend on where you've seen the light. It could simply be the the brushes that are arcing. Try to video what you see and post it so we can see what you see.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Engineer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 99
