Ana içeriğe geç
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
20 Soru Tümünü görüntüle
Xperia z3 : Unfortunately camera has stopped
After replacing my z3 screen , back camera front camera and flash not working anymore.. Also flashlight toggle disappeared from home screen .. I think problem is related to flashlight . When I connect my back camera the phone heats up and battery drains by 1 % every 2 minutes ..But when back camera is removed battery drains by 1 % every 2 hours ..
I tried every thing from factory reset , repairing through sony pc companion , tried other camera apps , changed camera sensor etc .. I came into point there is some short near camera or problem is due to flash (As flash light is also not working and flash toggle has disappeard from home screen .
Also please note on diagonistic front camera shows up but back camera doesnot shows up .. In camera app when clicked I get a message " Unfortunated camera has stopped " .
Can anyone genious help me find the solution ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
1 Yorum:
I have exactly the same issue as John. Camera not working, draining battery and heating, after a screen replacement. I've disconnected camera flat cable to preserve battery.
Did anyone find a solution?
I think it is a hardware failure.
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Any fix i having this problem right now
Help me please
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Some components on the PCB might be damaged, like the filter caps or resistors near the connector.
it could be either from corrosion (little moisture can still kill components on the inside), or from a shock when dropped.
Puan 0
1 Yorum:
Any fix i having this problem too
tarafından
Yorum Ekle
I also have the same problem, screen goes blank sometimes, camera has stopped working, tried software companion but it's still has the same issue. I just need to know if it's a hardware or software problem? Ave just formatted my phone, I pray that does the trick.
Puan 0
Yorum Ekle
o.m.g its frustation device i have ever use in my life, yes i have seen same issue in my cell, after everything done i believe that nothing function has helpful except given more money to service centre for changing damage camera, its is best solution for remove painful time which ever consume in our life. Such a bullshit cell .
Puan 0
Yorum Ekle
D6633 error camera not abaviable
Puan 0
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 7,193
