Ana içeriğe geç
Apple'ın 13 inç MacBook Air modelinin Mart 2015 güncellemesi, beşinci nesil Intel Core i5 ve i7 işlemciler içeriyor; bu da performans ve pil kullanım süresinde küçük bir artış sağlıyor.
Location of power pads
Macbook air with liquid damage, did a board cleaning and device powered back on. Now a couple month later it doesn't power up.
While trying to reset smc I notice there are no change to the charger indicator light. I suspect the power button has failed. I'm looking to jumpstart the macbook air to validate that, and if so, change the keyboard assembly.
I know Macboks usually have a couple power pads that can be bridged to power it up.
Does anyone know where they are?
thanks
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Emmanuel Marti check the attached image for location.
Resim
Bu yanıt yardımcı oldu mu?
Puan 10
7 Yorum:
Hi!
I have the same problem. I have now located the "debug power button". But does not work to press on them. How do you do it? And why did you put a red circle around the black thing?
tarafından
knutegil11 the red circle is from another guide where this image comes from. disregard it. you will need a flat head screwdriver or a paperclip to "bridge" the two contacts in the blue circle. If that does not work, then you are having plenty of other issues with your board.
tarafından
Ok, then I guess my Mac is broken for sure... Thank you for answering :)
tarafından
Before you get rid of it, track another ultrasonic cleaning with some Branson ec.
tarafından
@gigabit87898 why? knutegil11 did not mention anything about water damage or any other damage.
tarafından
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Emmanuel Marti sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 76
Her zaman: 25,636
