Ana içeriğe geç
1993 yılında piyasaya sürülmüştür, ekranın sağ üst köşesinde yazan TI-82 ibaresiyle tanımlanır.
Screen fading. What do I do?
There is a line down the right side that cuts the answer off. How can I fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Oh no! That sounds bad. Here, I don't have a Texas instrument calculator, but I can give you some tips! :)
1: Please check the volts on both the battery and the display, if they look fine, go to step 2.
2: Look for any damaged or misplaced cables. Sometimes they can cause a problem, oh and look for loose screws too.
3: If it still dosn't work, it might be a circuit board problem. There's not much you could do with that. We could buy another one on ebay, here's one I found. TEXAS INSTRUMENTS TI-82 PERFECTLY WORKING SCIENTIFIC CALCULATOR
Thank you for your patience! :D
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
@joilet This is a 8 year old question but somehow it popped up on the list. I am certain by now you either have it fixed or have a new calculator. Anyhow, this "line down the right side" and the fact that it is fading points to a bad display or corroded display adapter. Use something like this video to resolder the ribbon cable. If that does not work you may have to replace the screen. There are different versions for the screen, so you will have to get the LCD number from the current display since it will be specific to your calculator.
Puan 0
Yorum Ekle
Yanıtını ekle
Eden Brock sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 587
