Ana içeriğe geç
The Canon EOS Rebel T3i, released in March 2011, can be identified by its SKU (SKU:5169BO32). Also known as the EOS 600D and the EOS Kiss X5, this camera is a Canon Digital SLR with 18 megapixels.
SD card slot does not work
My SD card slot does not work anymore and I bought a new SD PCB assembly for it. (http://uscamera.com/cg2-3308.htm) Do you have a guide on how I could replace this? I could probably figure out how to do it myself, but it would make me feel better to have instructions
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Use this guide to remove the main board, which is probably the most delicate part of the operation. The SD card board is on the right side under the main board, and should be accessible once you remove the former. There are 3 connectors on the SD board: One flat to the main board, one wired two pin connector to the power board (top right) and one small flat that goes somewhere on the chassis (bottom left). Once all connectors have been detached, you can undo the 4 screws that hold the SD board, take it out, and fit the replacement.
Take utmost care not to damage the flat cables and the connectors. Some flat connectors have locking tabs that must be flipped up before you can extract the cable. Some large flats such as the one that connects to the sensor board have press fit connectors that pop out vertically (at right angle to the board), these should be carefully lifted out with the tip of a plastic spudger. Putting them back is easy, just line it up correctly and gently push it in place with your fingertips until it "clicks".
Once the replacement board is fitted, just follow the guide in reverse to put everything back together again.
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
Any other suggestions what this error could be caused by? I have replaced the sd card slot and am still getting "no card in camera"
tarafından
Yorum Ekle
If SD card slot is not working then you can remove the dust from slot or you can replace to SD card slot also.
Puan 3
Yorum Ekle
Yanıtını ekle
podraziya sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 4,997
