Fans are running faster.
Hello. I had been using my Mac about two weeks ago and then fans started to run at full performance immediately while i was browsing on the web. Luckily i have Windows 10 and Mac OS installed on the computer. Because on the Mac OS side, i am not able to boot it. I can not even pass the login screen due to slowness. But i can boot Windows 10 and use it with low performance.
Cases you should know:
- Hardware test error code: 4SNS/1/C0000008:THSP--124
- Mac OS has not even been booted since that day.
- Windows 10 is bootable but runs with 1/3 performance even though CPU usage is 2-3%.
- I had my Mac's motherboard repaired before.
I have done the hardware test and according to my researches, there is a problem with the temperature sensor. So i think computer thinks that CPU is getting so hot, then slows down the CPU and runs fans at full performance. I am still searching what the problem is. If you share your opinions, you make me happy.
Bu iyi bir soru mu?
Tell us about this repair please and why it was done, how long ago and who did it?
mayer tarafından
while i was buying mac, I bought an extra term of guaranty (similar to AppleStore's) from local tech shop. Apple's 2 years of warranty was ended so i had to give it to same tech shop and they sent it to be repaired, I have no idea where it is but probably it was not the official technical service. this was about 7-8 months ago by the way.
the reason was; my friend set on mac and then it started to show similar current reactions (fan speed, freezing etc.) Hardware test diagnosed a motherboard issue. Afterwards i sent it. although not yet certain I think they changed the motherboard. I dont know the details.
Burak Ozarslan tarafından
