Ana içeriğe geç
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
How to replace passenger floor fuse box
Can some one tell me how to do this please
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If your referring to the fuse panel that's located on the right hand side this may help.
https://www.youtube.com/watch?v=LTvGoVgf...
If your wanting to replace fuses this will help if your wanting to remove the panel itslef then you will need to remove the panels surrounding the fuse box to get at the retainer bolts . Once you have then retainer bolts out pull the panel out far enough to access the wire harnesses in the rear masking tap and a pen to label will help keep the plugs in order for easy reinstall and once all the harnesses are removed the panel is free to come out and replace with another panel. Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Yea it's the passenger floor panel what I'm really concerned about is if it will affect anything in the computer if I unplug everything and unplug battery first and install everything like it was...it's a 13 f150 platinum warranty is gone this is a work truck the has lots of miles my personal work truck want to make sure the ecm and power train etc dont get all confused and have to be all reprogrammed cause I can't do all that but the thing is and it's going to be a easy deal it looks like but it has lots of miles on it.
tarafından
The ecm will reset itself after it has been disconnected for about 20 minutes .The proper restart for the ECM is to allow the truck to idle for about 10 minutes . Don't rev it or drive it in that time . then when you do drive it be nice for the first little while so the computer can reset to your driving style . be smooth on acceleration and braking this will let the computer set to a moderate driving style and give best mileage. Yes it goes without saying to disconnect battery before doing this . it is also a good idea to discharge the ECM before hand . Did miss this step in the description to begin with. Once the battery is disconnected turn on all your lights to discharge the ECM and leave it like that for 20 minutes before starting to remove the panel .
tarafından
Yorum Ekle
Yanıtını ekle
Nick Looper sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 2,044
