Ana içeriğe geç
USB flash sürücüler (jump drive, USB bellek veya parmak sürücü olarak da bilinir) için onarım rehberleri ve destek.
How do I fix a DEAD flash Drive?
I have a Crucial 32 Folding flash drive. Worked fine on Tuesday night, plugged it in on Wednesday morning and... Nothing. Absolutely nothing! Problem is, it contains ALL my files (of course) which I need (of course). Is there a way to fix it myself (I have a "little bit" of electronics skills) , or should I send it off and jus pay the $$$$ to have it fixed and data recovered? Any ideas, suggestions? HELP?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 11
4 Yorum
Did you rule out the computer usb ports? If so, you can start with an electronics cleaner and brush in the flashdrive plug.
tarafından
Yes. Tried it in two diff computers. It "thinks" when I plug it in , then nothing. Opened it, no fuses or bad connectors . now what??? Is there a way to directly access the chip? Or can I take the chip out & put it into one that works?
tarafından
i have a dead usb and a I want to repair it. but no , i trying diskpart,mini partition and disk genius but no. but he doesn't want to create a partition for me pls a app he is reparing a usb
tarafından
hi there is t there a way to get access to a dead USB
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Before you take it apart try downloading easeus data recovery see if you can see your data there
Bu yanıt yardımcı oldu mu?
Puan 5
4 Yorum:
Good thought.
tarafından
@pccheese explain your vote on this answer to me.
tarafından
@oldturkey03 I have found no solution in the answer. It would be wiser to "remove as not an answer" than spam, though. My reason for a spam vote is because the recommendation of the software without any actual problem solving.
tarafından
@pccheese actually I think it is very wise to check recovery programs before a physical repair. I'd think spam if there would have been an actual link to it, but there was not. Looks like personal preference to me;-)
tarafından
Yorum Ekle
A BGA rework professional may be able to swap the memory to a new flashdrive, but without a hot air station you don't have a hope of switching it. Try pressing on the chips while you plug it in. Maybe it will work long enough to get your data. If not I would have to say send it in and pay. :(
Puan 1
Yorum Ekle
use partitionGuru Software
and change the drive letter maybe from E to R
Puan 1
Yorum Ekle
If your Crucial 32GB Folding Flash Drive suddenly isn’t detected, first try basic checks: use different USB ports, another computer, and avoid USB hubs. Check Disk Management (Windows) to see if it appears unassigned. If detected, don’t format—use recovery tools like Recuva or TestDisk.
If it’s completely dead (no detection), it’s likely controller failure—DIY repair is risky and can worsen data loss. In that case, professional recovery is safest. Avoid repeated plugging attempts, as it may damage the memory further.
Puan 0
Yorum Ekle
Yanıtını ekle
deadflash sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 45
Her zaman: 18,216
