Ana içeriğe geç
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Soru Tümünü görüntüle
CPU Fan is running full speed with normal temperatures
Hey All-
I just replaced my hard drive with a 3tb and added a ssd behind the optical bay using the kit and cable from OWC. Everything seemed to go fine and i've been able to re-install the OS.
However, now i've noticed the CPU fan only is running full blast, but the temperature sensors seem low. I've been able to slow it down using Macs Fan Control, but am very curious why this is happening. I could keep using this program, but i'd rather let the OS handle. I have reset smc and pram.
All temperatures are in the mid-30's (C)
Anyone have thoughts here?
Bu iyi bir soru mu?
Puan -1
1 Yorum
I did a hardware test and found that I am getting 4SNS/1/C00000008: TS2p--124.
From what I've read, this is a skin sensor, causing the CPU to increase. I double checked all my connections and it looks good. I did notice the right ambient sensor cable is a little frayed near the edge, but seems to be connected OK.
Anyone have any other info about this error?
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
The iMac logic board is pretty picky about the thermal sensors it recognises and will go into general fan panic if in doubt.
Do all your upgrade items have compatible sensors and are they all connected properly? OWC are pretty up to speed on this and may have guidance.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Adding the SSD didn't require any additional sensors and I did use the sensor cable for the replacement hard drive.
tarafından
After this, i took the computer back apart and put the old hard drive in. Still had same problem.
It looked like one of the top temp sensors was touching the case so i got some space around it. Put it all back together with my new drives.
Presto! no more cpu fan going nuts!!!!
tarafından
Yorum Ekle
En Yararlı Yanıt
Sounds like the OWC sensor is not doing its job. I would contact OWC to see if they send you a new one.
Puan 4
4 Yorum:
If that sensor was not working, wouldn't I be seeing my hard drive fan spin like crazy, not the cpu?
tarafından
Have you tried running TG Pro? It will allow you to see the sensors more effectively.
tarafından
Hi Dan-
I downloaded this and all my sensors look good..i can see my thermal sensors now, but TG Pro isn't reporting any hard drive sensors. HOwever, Macs Fan Control is showing both my hard drives...
Does this make sense?
tarafından
Yes, by default SMART is off which is why the HD's aren't being read. Unless I'm working on a possible HD thermal issue I leave it off as SMART requires an IRQ call which slows your system.
tarafından
Yorum Ekle
Have you changed the thermal paste?
Puan 0
1 Yorum:
I didn't change the thermal paste as I didn't remove the cpu
tarafından
Yorum Ekle
Have you run activity monitor and find out whats using your CPU more?
Puan 0
1 Yorum:
I don't have significant cpu usage, and all my temperature readings seem to be within normal range.I think Iain is on the right track, just need to keep digging.
tarafından
Yorum Ekle
Yanıtını ekle
Chad Predmore sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,837
