Shift key randomly ACTIVATING.
Hello all,
My MBP 7.1 RECENTLY froze after spending time in A VEry humid place(canyon lands of southern Brazil). When I restarted, it would only boot in safe mode. I figured something was wrong with the keyboard, so I replaced it and cleaned the inside, thinking some of 5 years' accumulated dust may have been partially responsible. After successful installation, computer was still slow(it was not so slow before I upgraded to El Capitan, seems i need more ram). Unfortunately, morning come, the same problem with the shift key had returned.
Is there a software fix for this?
Bu iyi bir soru mu?
2 Yorum
Your systems specs: MacBook Pro 13" 2.66 GHz Core 2 Duo (Mid-2010)
Dan tarafından
I'm seeing the same problem. Shift Key activates and won't let go. At first I replaced the keyboard but then it did it again. It so happens I was trying to render out an After Effects composition both times. The next time I rebooted without a keyboard connected and it went back to normal. Except when letters began to randomly capitalize while I was typing. Should I still attempt an OS reinstall as well? --- iMac Late 2013, maxed out
scriv tarafından
