Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Only works with speaker activated.
When making or recieving a call I need to activede the speaker on my Iphone othervice the I can't hear and the reciever can't hear me.
What do I need to change?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The most common source of this issue is debris in the headphone jack causing the sensor inside to continually detect headphones. This in turn forces the phone to turn off the receiver earpiece and mic. The most common source of this debris is pocket lint, BTW.
You can also test this by playing a track in iPod mode - if it doesn't play thru the speaker, and the volume control indicates headphone adjustment with no headphones connected, then the sensor is being triggered.
Try blasting compressed air into the headphone jack in a series of short blasts. The debris can also sometimes be cleared by repeatedly inserting and removing headphones from the jack.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Have you taken your iPhone apart? If so, it could be that ribbon #3 is out of place- that one corresponds to the earspeaker.
Puan 0
Yorum Ekle
How far is the #3 cable supposed to go into the phone? it looks as if there is a white line with an arrow pointing to it. Should it go in that far, or only until the "light" colored brass in all the way in?
Puan 0
Yorum Ekle
i dont think it goes all the way to the line, well i couldnt get it that far and it wasworking fine.
Puan 0
Yorum Ekle
Yanıtını ekle
kim sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 6,605
