Can't entering recovery mode
hi please can you help me my phone when i boot into recovery mode it gives me e:failed to mount system and don't enter into recovery.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
That means the chances of getting the phone back into a working state via recovery is 0%. You will have to attempt restoring the system software via download mode which is done by this:
(Before you follow the steps below, make sure your phone is turned off then booted to download mode by holding Volume Down, Home Button and power button. For a few seconds until the download mode confirmation dialog is shown. Make sure to accept booting that mode via volume keys when prompted.
You may need to restore the software on your phone via Samsung Kies. You do it via Tools > Firmware upgrade and initialization. This will prompt you to enter the model number and the serial number of the phone which is usually at the back of the phone or in the battery compartment.
If the Samsung Kies method does not allow you to download the firmware for your phone then you'll have to go to http://www.sammobile.com/firmwares/ where you type your model number of your phone to find the firmware for your phone. Make sure you choose latest version to the network it was mainly with.
Samfirmware instructions (After the file has finished downloading):
You can alternatively use the program called SamFirm to download samsung firmware at full speed (latest firmware updates only) or Updato (http://updato.com/firmware-archive-selec...) to download firmware too.
Bu yanıt yardımcı oldu mu?
hello there..I followed the procedure as described but upon finishing,the phone is still stuck at the boot loop..How do i go about this?
Try doing a wipe data / factory reset through recovery mode and see if that helps, you could also have a bad data partition.
The command,volume up+ home button+power button is not successful.The volume down+home button+power button is working and is putting me in the download mode whereby I managed to flash the phone through odin but the phone ended up being stuck on the logo upon restarting.
Its a samsung phone
no
it gives link to dwonload for money
and i dont have cridet card or cash
If you know the version of your i9200, 8GB or 16GB, it can be rescued. But you have to be sure of which one it is.
hi there i followed the steps on how to get in to odin mode or download mode i have samsung galaxy A6+ and when the phone is powered off i press the power button and the volume down key together at the same time so it appears the bootlogo and the odin mode don’t appear so how can i fix this problem please help me
I am having the same problem, However I manage to get in odin mode by doing the steps in following manner
1) Plug in USB cable connected to pc at one end (phone will start and get stuck in reboot mode), dont worry, let it continue
2) PRESS Volume Down key + Home key (don't press power key)
phone will get into boot mode
hi guys.
I tried firmware hard reset through odin3. it failed now my phone constantly restarts into recovery mode but only for a second, and goes on in an endless loop....
please help me guys.
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 23
Her zaman: 35,826
