Ana içeriğe geç
Sony tarafından üretilmiş, 11,6 inç dokunmatik ekrana sahip bir tablet ve Full HD dizüstü bilgisayar. 2012 yılında piyasaya sürülmüştür.
How can I replace LCD Screen?
The Sony Vaio Duo 11 screen is blurred and some bubbles and must be replaced. I did not find service manuals on the Sony website.
How do I replace the LCD screen of my duo11. Someone has removed the screen of a 11 Duo or something similar?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 12
16 Yorum:
Sadly, the link you provided says the item is now discontinued & it doesn't provide tech specs to help find an alt. supplier.
From searching to replace my(failing/delaminating AMOLED) orig screen, I found links on alibaba.com/aliexpress.com suggesting custom styled one of these (Panasonic VVX11F019G00) works as a replacement for a Sony Vaio Duo 11.
http://www.panelook.com/VVX11F019G00_Pan...
https://www.alibaba.com/product-detail/L...
https://www.aliexpress.com/item/NeoThink...
The only problem I can see is sourcing from a location that will sell them individually, or sourcing in the country I live in, so that if the claim of Duo 11 compatible isn't true, returning it won't result in losing money in shipping and import taxes. Will probably email a VVX11F019G00 ebay seller about one for a Duo 11 and report back if it works out.
tarafından Paylaş
Hi! I had the same problem and realized the replacement of the screen of my Vaio Duo 11 without problems. I got the full screen (with the touch digitizer) from EBAY and I followed this video from Sony that shows how the Duo 11 is mounted: https://youtu.be/2mLiCBhczTA
tarafından Paylaş
There is another place to try to found the screen: http://www.laptopinventory.com/ModelDeta...
Before buy, ask him if will work in our ultrabook.
tarafından Paylaş
And the correct model of your equipment is printed back the screen case (at the up right side).
tarafından Paylaş
11 tane daha yorum göster
Yorum Ekle
6 Cevap
Filtre ölçütü:
I have a sony vaio duo with a bad screen. I went into pc settings in win 8.1 and told the screen to only show the 2nd screen which is a 27 inch vga plug in screen. It asked me if I wanted to make it primary and I said yes. Now the bad sony touch screen is completely out of the picture. I tested the 27 inch screen on a restore of image and it came up fine - whew. So try declaring 2nd screen only and see if the pc asks you if you want to make it primary....Gene
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I have a burned out screen on my sony vaio duo pc also. I can plug in a remote monitor and use it. However if you need to do a restore of an image you cannot do it with the sony screen in place that is not working. I have searched world wide for a replacement screen. It seems the screen does not exist. So I decided to try an experiment and just remove the sony vaio duo screen. You can pull up on the screen well enough to remove the screws to get the screen off. Be sure power is off. You can unplug the cable from the screen. I cut my wifi cable and I have a modem close enough to the pc to make it work. Take a look at the pictures I have posted here http://egpreston.com/sonyvaio.pdf
Puan 0
Yorum Ekle
You don’t need an exact replacement.  You can plug in an HD monitor in the hdmi port and if the old screen is completely disconnected (just cut the ribbon cable with power off) and the sony vaio will see the hdmi screen as its main screen.  Here is my web page on this topic:  https://egpreston.com/sonyvaio.pdf
Puan 0
Yorum Ekle
Remove the broken screen entirely and plug in an hdmi monitor. There are no replacement screens.
Puan 0
1 Yorum:
I've taken a good screen off of another vaio duo that had a problem with the power input. Now with the new screen fitted it won't power up at all and shows no LEDs lit up even when plugged in and supposedly charging.
tarafından Paylaş
Yorum Ekle
I found this …
https://sony.x-comp.at/store-products.ph...
Puan 0
Yorum Ekle
Actually I buy a VVX11F019G00 panel and found that the connector is not compatible with the original FPC cable. And panel PCB not the same. VVX11F019G00 using 30 pin eDP connector and LP116WF1-SPA1 using 35 pin FH35W-35S-0.3SHW connector. You can't connect VVX11F019G00 to the cable directly. Maybe someone can design a custom made FPC cable to connect them. Or remove COF and PCB to VVX11F019G00 (very likely not possible). But it's out of my depth.
I will remove the panel and buy an external monitor, magnetic holder parts. Then suck the external monitor on the original place of the panel.
Puan 0
Yorum Ekle
Yanıtını ekle
Veberson Merlo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 59
Her zaman: 25,542
