I can"t power on
I dropped my Beats pil in the water and I dried it off. It worked the rest of the day and then the next day it would not work. I charge it and the power light doesn't light up nor does it seem to charge.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Danny Griffith the drying off is just not good enough. you will have to disassemble it and clean the circuit boards with some 90+% isopropyl alcohol and a soft brush to displace all the water etc. Then you will need to replace the battery. It is a must to do that. Once you did all that, re-evaluate and see what happens. It is possible that you shortcircuited the board through the water damage. Any component on the board may have failed, so you will have to take a real close look and see if you can visualize any damaged component. Use these guides to work on it.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 24
Her zaman: 3,645
