Digital display nor radio not working when plug it in.
When I plug in the RCA 100A clock radio, it does not flash, radio does not come on. There is a light under the bottom that will come on. How can I fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If you are lucky, there may be an internal fuse that may be blown or the power cord may jis be bad (a breal in the corace near the plug oreally the clock itself). Understand that I'm not familiar with this clock radio, and it may be that you might simply have to replace the clock radio. If you are familiar with a multimeter you can track down where the power stops or if the circuit board itself is bad.
Good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,130
Hi, Could you verify the model please? Is it an RC100 as per this link? http://www.rcaaudiovideo.com/audio/clock...
jayeff tarafından
The alarm is not working on my digital radio even though the alarm light is on
Caz tarafından
@cazmeringue
What is the make and model number of the clock radio?
Does the radio turn on (not the buzzer) when the alarm goes off?
jayeff tarafından
