Ana içeriğe geç
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
371 Soru Tümünü görüntüle
Replacement for rubber feet located at the upper back plate
Are there any website that sells rubber feet located at the upper back plate of the device? If not then is there any way to make it adhesive enough without using liquid-based adhesive like superglue?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @faux I got the easiest solution for you and here you go. http://www.amazon.com/Self-adhesive-Clea... I use these alot and even though they are clear they do the exact same thing and all you have to do is peel them off and stick them to whatever I use them on electronics, tool cases, Ifixit 64 bit kit and what ever I don't want to slide which is what those original feet did but they are just clear instead. I hope this helps
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
J Gab sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 661
