Ryobi Strimmer Not Priming
Hi, I'll try and make this not sound too confusing..
Last week I was using my Ryobi 2 Stroke petrol strimmer, Everything was working fine with it, started fine, ran fine ect...
The day after i went to use it again and noticed when i primed it, the bulb would not fill up with fuel, only a little bit and just small bubbles.
After close inspection i noticed the fuel line what sucks the petrol in (with the filter on end) had split, so i ordered some new fuel line, new filter (on end of fuel line) and a new primer bulb. Fitted it all but still had the same problem.
So next thing i thought maybe the carb is blocked somewhere so i removed the carb gave it a full clean from top to bottom, refitted and still same, the primer bulb would not fill.
So i ordered a rebuild kit for the carb. Rebuilt it by following a video on youtube. Refitted the carb, still no luck.
As i was trying to prime it, my friend noticed quite a lot of fuel dripping from the bottom so after close inspection i noticed the new fuel line i fitted, the fuel was leaking over the top and realized when i pulled it off the carb it came off too easy (and also went back on too easy) not really much give so im not wondering if this could be the problem???
I have tried everything and just cannot get to the bottom of this hope somebody can help me .
Oh by the way, I noticed aswell (for some strange reason) when i loosend the right screw which holds the primer bulb in the fuel came into the bulb really fast but when primed it was leaking also sometimes when the bulb was pressed it didnt come back up (until i loosend that screw). Strange
Bu iyi bir soru mu?
4 Yorum
Hi, Not sure if this is a help or even relevant to your problem but here is a link for servicing a 25cc motor. Download and then search for 'primer' in the document for information (Control + f key works the best to bring up search box)
http://www.mymowerparts.com/pdf/MTD-Serv...
jayeff tarafından
Hi I have a Hitachi 2 cycle weed wacker and I am having the same problem but I can't seem to figure out why the fuel won't go in the bulb and why it is leaking gas everywhere. If anyone knows how to help please say so (I'm16 and its my deployed dads weed wacker)
Christian Hammond tarafından
Also anyone know a website that I can go to for a troy-built pony 7 gear riding mower deck my dads is badly bent in and the welding is coming undone (please let me know and thanks)
I have a Ryobi petrol strimmer with the same issue. Cleaned carb, pipes, in tank filter, the fuel pipes, etc didn't work but I had another Ryobi multi tool so I swapped the entire tank and pipes. The fault follows the fuel tank and it has something to do with the pipe fit in the holes. I ordered a fuel tank with pipes and filter fitted online for £25 and problem solved.
Shaun McCormick tarafından
