Ana içeriğe geç
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
84 Soru Tümünü görüntüle
A1267, MB382LL/A everything but lcd backlight working
I just got a used 24" LED Cinema Display. Everything works except for the LED backlight. By everything, I mean the sound, USB, camera, the LCD display...
I can shine a flashlight on the screen and see the display working, but there's no backlight.
i've checked and re-seated all cables, and I can't find anything fishy other than this VR. it seems to be a little brown around the solders, and the plastic protector on the back of the logic board has melted a bit directly beneath it. the regulator is the center one.
i've run through the apple troubleshooting flowchart, but i don't know where TP81 (test point) is.
thanks in advance
Bu iyi bir soru mu?
Puan 0
1 Yorum
ok, i found the diagram and tested the correct voltage at every point. i ran through both the BLANK/NO VIDEO and DEAD/NO POWER flowcharts, and everything tested ok. at this point, i'll have to assume i've got a bad function cable, or bad LED backlight?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
eBay logic board $92.99
all is well
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Hey - I've got a similar problem - just wonder if the logic board fixes the backlight? Or was it something else? If you see this, I appreciate your answers! Thanks!
tarafından
yes I replaced the board, and the monitor is currently still in service!
tarafından
Yorum Ekle
Yanıtını ekle
Ronnoc Nailli sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 2,442
