Top of the screen is much darker than rest
The top of the screen {like 1/4} is darker then next has lines going through it. The rest is fine.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I am in the process of repairing a Samsung ln40b530p7n with similar issues as you are experiencing. After testing voltages with a multimeter I found the gamma IC on the t-con board has incorrect voltage readings in a few areas. On the board I'm repairing there are 22 test points on the t-con board to check the gamma IC voltages. They are labeled on the t-con board as VGMA1-VGMA22. When checking the voltages they should decrease in voltage in one direction. So for example:
VGMA1: 15.23v
VGMA2: 14.97v
VGMA3: 14.83v
VGMA4: 12.61v
VGMA5: 11.77v
VGMA6: 10.79v
VGMA7: 10.06v
VGMA8: 9.72v
VGMA9: 8.38v
VGMA10: 8.23v
VGMA11: 7.78v
VGMA12: 6.99v
VGMA13: 6.79v
VGMA14: 6.60v
VGMA15: 5.25v
VGMA16: 4.82v
VGMA17: 4.60v
VGMA18: 3.59v
VGMA19: 2.65v
VGMA20: 0.65v
VGMA21: 0.51v
VGMA22: 0.29v
I found the voltages for VGMA14 @ 7.37v, VGMA15 @ 12.45v, and VGMA16 @ 9.92v. So the increase in voltages there signal a failing gamma ic. The gamma IC is a AS15 F on the t-con board I'm repairing. I believe your t-con board also has an AS15 gamma IC. It seems that these ICs are known to fail. So if you or someone you know can check the voltages in the area I have mentioned with a multimeter than you may be able to determine if the gamma IC is indeed the issue. If so you can find a replacement t-con board or for a harder but far cheaper repair you can just replace the bad IC. I recommend www.shopjimmy.com for TV replacement parts. Hope this is helpful and let me know if you have any questions.
Bu yanıt yardımcı oldu mu?
check whether there is a device with a stong magnetic field above the screen, such as a transformer or speaker.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 842
1 Yorum
I think this is a default in Samsung led tv which must be seriously answered by the manufacturer, they said that this is due to a bad power supply which I am sure it is a wrong answer.
foufhanna tarafından
