Ana içeriğe geç
Released in 2008, has 30 pin connector (can be used with iPhone 4S and below) which will not work with newer models. The main differences between this model and the first edition is the remotes layout and color. Product features include: rechargeable lithium-ion battery, rotating docking system, remote, portable, built in carrying handle, and Bose quality speaker.
14 Soru Tümünü görüntüle
Why the green light is permanent?
Hi, my Bose SoundDock Portable v2 has the green light permanent, and a i can´t use it. I can´t turn up the volume or turn down, and don´t reproduces the music.
Bu iyi bir soru mu?
Puan 0
1 Yorum
It worked like a charm !! Thanks !
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Is this with both the buttons on the device and the remote?
Bu yanıt yardımcı oldu mu?
Puan 3
13 Yorum:
No, when i press the buttons on the device or the remote, my bose doesn't make anything, the green light stay permanent
tarafından
I'm certain you've tried unplugging it and waiting a while before you use it again. Also I'm wondering if it works while its plugged in. It could be a faulty battery, for which you could Bose SoundDock Portable v2 Battery Replacement replace the battery
tarafından
i have the same problem with my bose soundock series ii, the bose sevice center told me that it need to replace the sound processor module but very expensive so i try to repair it myself, i found out that the crystal oscillator 16.974mhz is not working properly, tried to replace it but no luck, so i solder a 22pf capacitor to one pin of crystal to ground, now its working.
tarafından
Hey Marvin, you didn;t happen to take a photo of your completed fix? Thanks,
tarafından
Hello Marvin can you please attached the photos so it will be easy to fix the issue mine have same problem please help
tarafından
8 tane daha yorum göster
Yorum Ekle
This is the fix you need
Puan 1
4 Yorum:
22pf ceramic capacitor
tarafından
Thank you, worked like a charm
tarafından
22pf capacitor 50v?
tarafından
It worked like a charm ! THANKS !! How did you find this solution ?
tarafından
Yorum Ekle
hello do you have to regulate your problem??
Puan 0
Yorum Ekle
Hello all. My SoundDock Series II does the same thing. For a while the green LED would stay lit after a power outage, but would be fixed by replugging the power cable on back of unit -- now that method doesn't work. I suspect there is an issue with the power supply, or with the power stable circuit. I will pursue this problem and post any conclusions.
Puan 0
1 Yorum:
Would like to know what the fix is for this issue when it's available, would like my SoundDock working again.
Thanks.
tarafından
Yorum Ekle
Yanıtını ekle
Romer Alvarado sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 34
Son 30 gün: 106
Her zaman: 6,814
