excessive noise from coolers after replacing hdd
The new HDD is installed on the imac has no temperature sensor connector and cable leave that loose. That is not connected. I closed the imac and OSX install correctly. But the problem is that the cooler makes excessive noise. Probe smcFanControl or programs like fancontrol but I had the solution. I recommend doing to fix this problem?
Best Regards!
Bu iyi bir soru mu?
