Ana içeriğe geç
Dead after screen replacement
Hi all-
My iPhone 6 Plus was working fine, but had a cracked screen. After replacing the screen using the iFixit kit, the phone is completely dead. It will not power on, reset, or respond to iTunes when plugged into my Macbook. It does get warm when connected to the charger, but that's it. Any suggestions?
-Garland
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
I think a cable is not connected, open the phone and look if everything is connected.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yes check all your connectors to make sure they are connected correct. Unhook the battery from the motherboard and then reconnect after 10 mins, power up and see what happens. Do you know what % your battery was at prior to doing the screen replacement?
Puan 0
Yorum Ekle
Plug it into your Macbook, and do this: iPhone 6 Plus'ı Manüel Olarak Yeniden Başlatma
If it doesn't show up then it's probably the logic board. I would open up the phone again if the method above doesn't work, and check to see if any components missing off the logic board by the screen connectors.
If it does however show up, then I would check to see if normal things are working such as the silent switch or Siri. If they don't (I had this happen to me on my 4s) then it might be the logic board (in my case it was).
Puan 0
Yorum Ekle
Yanıtını ekle
garlandstephens sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 216
