iPhone 6s rear camera lens
The rear camera lens on the 6s has a small crack in it. The camera works fine and so far it does not seem to i,pact picture quality. I was wondering if there was a way to replace this cover?? Thanks
Bu iyi bir soru mu?
Bu iyi bir soru mu?
the rear camera lense is solder on the housing you will have to pry it. iPhone 6 Camera Lens Replacement here is the guide this for the 6 but it applies for the 6s as well
Bu yanıt yardımcı oldu mu?
if you see the video it doesnt come out that easy you will have to pry that bracket off. and then you can push it down easily i have done this alot.
Yes, but it has to be done internally. You'd follow the guided to replace the rear camera, but you'd take it one step further and use a ink pen or mechanical pencil and punch the lens out. The lens will fall out the back.
i am trying to replace my rear camera lens too but it simply wont come out ive tried with all sorts to push it out but it wont budge... help
Have you tried pushing it from the inside of the phone out the back?
Yeah the video and guides make this look like an easy repair, but it's pretty difficult because that bracket that holds the rear camera is riveted to the frame of the phone. Be sure to order a new bracket because it's nearly impossible to not damage the bracket during this repair.
yeah, I've seen people mention that. any idea of source or proper name of that component?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,950
