Ana içeriğe geç
2010 Ortası Model A1278 / 2,4 veya 2,66 GHz Core 2 Duo işlemci
Are Torx Security bits compatible with non-security bits?
I am looking to upgrade my wife's old Macbook Pro with an SSD, following this guide: MacBook Pro 13" Unibody Mid 2010 Sabit Disk Değişimi
It says we need a T6 Torx screwdriver. I thought it was weird that the driver kits being sold by iFixIt wouldn't include anything higher than T5 for non-security Torx bits, but then I saw the following on this page: TR6 Torx Security Screwdriver
"Security drilling on this driver makes sure that you won't be stopped by anything, even though this driver still works great in non-security T6 screws as well."
So, can anyone confirm if Torx Security bits are compatible with Torx non-security bits, and does this hold true for all Torx bit sizes?
Precision fixed blade screwdriver engineered by iFixit. Görseli
Ürün
$5.99
Bu iyi bir soru mu?
Puan 9
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The difference between security torx and standard torx is the hole drilled in the center, this allows the driver to slip over the pin located on the security screws. Otherwise they are identical sizes.
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
is just the hole the difference? both share the same sizes?
tarafından
Yorum Ekle
En Yararlı Yanıt
Of course they are, all it is, is an extra hole.
Puan 7
Yorum Ekle
Yanıtını ekle
Help Computer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 25,306
