Ana içeriğe geç
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Soru Tümünü görüntüle
Is it normal to have white paste inside charger or something leaked?
I decided to replace a cable in my MacBook charger (old MagSafe). I cracked it open and there is a large blob of some sort of white rubberish paste filling a good portion of the space inside:
I am not sure whether it is a special filling paste or something (capacitor?) leaked. I was not able to find any obvious sorts of leakage.
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The white rubbery stuff is indeed a filler, I think it may help conduct heat towards the shell so as to avoid the formation of hot spots in the circuitry. It also helps to keep the components in place, which is a good thing because power bricks are relatively prone to rough handling.
Of course, it also makes the power brick more difficult to repair, but then, power bricks as a rule should be replaced, not repaired. Repair of power bricks by non-experts in particular are not unlikely to present a significant safety hazard.
Bu yanıt yardımcı oldu mu?
Puan 5
3 Yorum:
I just replaced the cable by unsoldering the old one and soldering new one. I would barely call it a repair. The place where wires were soldered was not covered by the filler, so it was not hard at all.
tarafından
There's always the exception that confirms the rule ;)
However, one should keep in mind that a carelessly executed repair might compromise the galvanic separation between input (mains!) and output (the equipment being powered, and by extension, your body).
tarafından
Thanks I will keep it in mind.
tarafından
Yorum Ekle
Yanıtını ekle
Andrey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 47
Her zaman: 5,104
