Ana içeriğe geç
Released September 14, 2012, Apple's EarPod headphones are a new revision to their iconic white headphones. Model number: MNHF2AM/A.
58 Soru Tümünü görüntüle
How to fix ripped headphone cords
How do you fix the apple headphones when the cord is ripped?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you feel comfortable, get some fine heat shrink, a soldering iron and some solder and solder the proper wires to each other. Put the heat shrink on before you solder (slide it down so that the heat from the soldering iron doesn't cause it to shrink prematurely), then slide it over the repaired area and use a hair dryer, heat gun or lighter to shrink the tubing. Keep in mind that the wires inside are VERY small.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
u just put the cord part that's broken in the hole to the device
Puan 0
3 Comments:
That would short out and kill the phone... -_-
tarafından
It most likely won’t short the phone, but you’re essential just sticking wires blindly into a hole.
tarafından
thxs for helping me
tarafından
Yorum Ekle
Hunter - you mean the cord (the wire) is broken ? Segi's answer is correct.
OR....
the ear-plug has been torn from the wire ? That's not repairable. Do Not plug it in.
Puan 0
Yorum Ekle
Yanıtını ekle
Hunter Bagan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 10,159
