Ana içeriğe geç
"PS2" olarak bilinir, Sony tarafından Japonya'da Mart 2000 tarihinde satışa sunulmuş altıncı nesil bir oyun konsoludur. Amerika onu 2000'in sonuna doğru SCPH-30000 ile gördü. Bu cihazın tamiri sadece genel araçları gerektirir ancak tamir zorlayıcı olabilir.
199 Soru Tümünü görüntüle
Soru Kapandı
Realigning a new laser in SCPH-30001R
Hi Everyone,
I recently replaced the laser in a SCPH-30001R, and realigned the laser so that it could read discs. After I realigned it though, it would only play PS1 discs and blue PS2 discs. When I would try to test a silver PS2 disc or my laser cleaning disc, the drive would making buzzing noises. (Versus no buzzing at all with the PS1 and blue PS2.) Should I keep trying to align it, or I'm I missing something? The laser model is a KHS-400C, the same model that I found in the system before replacement. When I first installed the laser without any adjustment to the laser angle, the system would not load any discs.
On a side note, I have another SCPH-30001R, that takes longer than normal to load a disc. Is there anything I can do to improve the load time?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@supportninja you can try to further adjust the laser and see if that will work. Of course it will also depend on how your are adjusting it. Take a look on here as well as the answer Disc is not spinning with a new laser PlayStation 2 for that. There were issues with the laser and the alignment on the PS2.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
I think I know what the problem is now - When I installed it, I am fairly certainly I screwed in the angle screw on the rod all the way. I'll give adjusting it a try and post the results.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,709
