Ana içeriğe geç
Kenmore Elite HE3, Kenmore tarafından üretilen 7,2 fit küp kapasiteli bir elektrikli kurutma makinesidir.
Dryer not turning on.
Dryer won't turn on when power button is pressed but the light inside the dryer comes on when door is open. What is wrong with it?
Bu iyi bir soru mu?
Puan 3
10 Yorum
@webert3017 what have you tried thus far? Unplugged it for a while?
tarafından
Kenmore Elite HE3 dryer. Turns on, clicks, lights on no error code comes up. I have checked all fuses, sensors all with ohms meter and are good. Drum is not turning nor is motor. It will even run thru the time cycle as if it was drying?
tarafından
Mines exact same did u find anything
tarafından
Mines is exact same did u find anything?
tarafından
My Kenmore elite is doing this it turns on even gets hot inside but does not spin but if I let it run it smells like something is burning
tarafından
5 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown out. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Cause 2
Start Switch
To determine if the start switch is defective, attempt to start the dryer. If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a multimeter to test the start switch for continuity. If the switch does not have continuity, replace it.
Cause 3
Door Switch
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the “click.” If the door switch makes a clicking sound, it is probably not defective. If you don’t hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
Turn on dryer runs alittle tjen shuts off and all buttons flash?
tarafından
do u have picture where the thermal fuse is locate at
tarafından
would like a pitchure ofdi grame
tarafından
Yorum Ekle
Step by step procedure. http://www.repairclinic.com/vwo12
make sure your vent hose is not crimped/plugged, also clean out the vent housing at the end of hose, outside. House fires/plugged dryer vents.
The dryer stays cool by having an UNrestricted air flow thru hose, otherwise parts heat up and fail.
Clean the filter after every load or else you will develop the habit of not cleaning it.
Puan 2
Yorum Ekle
If the dryer won't do anything, the belt may be broken or may have come off of the tension pulley. Either trips the belt switch, which disables the motor. If the motor won't run, the dryer won't heat.
Puan 1
Yorum Ekle
Yanıtını ekle
Tyler Weber sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 53,462
