Ana içeriğe geç
The Motorola Droid 2 (A955) is the fifth phone in Verizon's Droid line.
13 Soru Tümünü görüntüle
How to repair if Radio Reciever burns out?
The WiFi would freeze when showing it was turning off which started causing phone to turn off & back on by itself but would freeze on reboot. Had it reformatted, but still keeps shutting off & on after about 10 minutes. Stays on Airplane mode so cant make calls. Was told was from wireless radio/receiver was burnt out. Is this difficult to fix? What would need to be done?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I believe this transmitter is part of the main board and is not user-replaceable. You may need to replace the whole mother/LogicBoard.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Then wouldn't that actually be easier?I am getting different explanations from people.*it's the software that was used to flash it, *Its a hardware issue,*no, it's a software issue that whoever flashed it should be able to fix it *or we can do for $120,*we have "special droid flash software" that will correct all of that". This is worse then a crossroad. I have no idea which direction I should follow??
tarafından
Yorum Ekle
follow your heart...
Puan 0
Yorum Ekle
Yanıtını ekle
lizrfresno325 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,376
