stays black when you turn it on
my computert stays black when you turn it on wwhy
Bu iyi bir soru mu?
Bu iyi bir soru mu?
K SEARS could be caused by a bad backlight, bad LCD panel or bad GPU. First thing you want to do is to attach an external monitor. If you have a proper image with that you know that your GPU is ok (motherboard). Then focus on your LCD. Check with a flashlight by shining it at an angle against your LCD see if you can make something out. That would be a failed backlight possibly caused by a bad inverter. Check on here how to fix it. You can also download the service manual from here which will show you the inverter as well as LCD replacement procedure.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 114
