Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
iPhone 6 Screen Replacement Light Leakage
So i've now gone through 2 replacements of the complete assembly (minus touch id) from different suppliers and I am onto a 3rd, however consistently, there is a small gap of light leaking from the mute slider and there is a visible raise when compared to an original.
Almost certain the phone isn't bent as an original screen doesn't have this issue.
Is there any way to fix this with a small amount of adhesive or anything else? I have reseated it a couple of times to the same result.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Lewis,
I have seen this on a few iPhone 6 screens. The housing is completely straight. Right?
It really shows up on the black iPhone 6. I open it back up and on that side run a piece of black electrician's tape to overlap the back light. It has to be right at the top to about half way down the screen. Trashy I know- but it works and have never had one come back.
Other option is you can pay to send the screen back and they will send you another one with the same problem.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
Get a good quality screen from a different supplier. These screens will soon lift from their frame.
Alternatively place a strip of black tape on the edge of the LCD (inside) to cover the side that leaks light to the outside. Originals have this piece of tape.
Puan 4
Yorum Ekle
I've been using the tape fix but it still doesn't answer why it's happening. I've bought OEM products and it still happens.
Puan 0
1 Yorum:
Bent housing can cause this too.
tarafından
Yorum Ekle
Yanıtını ekle
Lewis Watson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 7,947
