Ana içeriğe geç
Samsung Galaxy Note 4, Ekim 2014'te piyasaya sürülen hücresel bir akıllı telefondur. Galaxy Note 4 model numarası SM-N910'dur; Amerikan varyantları için SM-N910A, SM-N910T, SM-N910V veya SM-N910R4'tür.
Note 4 from Verizon stocks in a boot loop
Hello!
I have a SM-N910V to fix a boot loop. I made a Odin flash with the last firmware and previous firmwares but when flashing ends it reboot and it stocks in a boot loop on Galaxy Note 4 logo and the upper left side of the screen shows a blue "recovery booting" and vibrate.
Anyone have a suggestion?
Thank you
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
So it won't allow you to boot recovery mode even after a firmware flash? I'm puzzled. Try having the phone off then hold the Power + Volume Up and Home button until you get the blue 'Recovery Booting' text and wait for it to boot recovery. Should take around 10-20 seconds.
Then you will have to do a wipe data / factory reset most likely in order to fix this boot loop issue. Make sure you are running latest firmware and not previous ones as this can cause issues if using too old of firmware.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I do every thing you suggest and it stocks in a boot loop and it won't allow to recovery mode....
tarafından
Yorum Ekle
So, try the reset sequence when the phone is plugged in. After reading the last comment about the battery issue I thought maybe my battery was just messed up. Turns out I was right. I was able to reset and reboot while plugged in. I'll grab a new battery tomorrow…
Puan 1
Yorum Ekle
I solved this problem by replacing the “no name equivalent” battery I was using with a SAMSUNG battery. The no name battery measured 4.3 volts…..it’s supposed to be 3.8 volts.
Puan 0
Yorum Ekle
Yanıtını ekle
Ruben Lopes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 5,699
