Ana içeriğe geç
Mr. Potato Head, ana gövdeye takılabilen çeşitli plastik parçalarla süslenebilen, plastik bir patates modelinden oluşan bir Amerikan oyuncağıdır.
Grinding sound won't move
My Toy Story Collection talking mr potato won't move his legs like it's supposed to and is making a grinding sound how to fix it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Please let me know how you fixed it ???
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
  1. The Real Mr. Potato has no moving Parts. He doesn't move either, at least on his own.
  1. Open up Mr. Potato's back and dump out the innards.
# Have fun!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Gearbox gear repair.
It seems to be a fundamental problem for the product.
All the problematic products are the same gear problem.
The two gears in question must be repaired by opening the gearbox.
It would be easy to get the same gear, but...
A gear is cracked.
The thickness of the steel pipe in the middle is larger than the gear hole, resulting in a crack.
Secure the cracked gear with glue and expand the hole.
Grind steel pipes to make the hunger thin.
https://youtu.be/4QJFvA5n3gs
업데이트 (2019년 10월 23일)
The cracked side of the gear needs to be cut and glued. This ensures a constant gap between the teeth.
Resim
The gears were first disconnected and then polished the bumpy part of the metal pin.Cut off the cracked part a little and fix it with a force adhesive. Apply a little glue to the metal pins and fasten them with the gears.
Puan 1
6 Yorum:
Do you have a diagram of how the gears fit together?
tarafından
@weirdalfan1 No, i have not. Cut off the cracked part of the gear. Because it is to fit each gap in the gears. This is important.
tarafından
Hi there please can you help me. My mr potato head is also broken. He talks but does not wobble. Could you maybe do a step for step guide with photos on how to fix him..... im part of a toy story collection group on facebook and it seems to be a regular problem. If you could do that im sure you would help allot of people we all struggling.please please pretty please. I love my mr potato head and so badly want to fix him i have spent days trying to figure it out but havnt come right. :(
tarafından
The repaired product was not mine. The repair process was complicated, so I didn't take many picturesI'll organize and let you know the photos I took at the time. If you ever visit Korea, I will help you.
tarafından
@Antoinette Botha The repaired product was not mine. The repair process was complicated, so I didn't take many picturesI'll organize and let you know the photos I took at the time. If you ever visit Korea, I will help you.
tarafından
1 tane daha yorum göster
Yorum Ekle
Step-by-Step Fix
  1. Disassembly: Document each component’s position and assembly order with photos.
  2. Gear replacement: Swap the damaged gears with precision-matched custom gears.
  3. Lubrication: Apply silicone-based grease to all moving parts.
  4. Reassembly: Reverse the disassembly sequence strictly.
Resim
Resim
Resim
Simply using glue to repair a broken gear often doesn’t work. Initially, I tried that approach too, but the result was that it still jammed. Because the gears in Mr. Potato Head are very precision-engineered, I ended up repairing it successfully by replacing the gears with custom-made ones
Puan 1
Yorum Ekle
Hi hi, i wanted to find out did you manage to fix your mr potato head? Mine is doing the same thing…he speaks but no longer wobbles. Please help. It must be the gears … i glued the 2 cracked gears but when i put him back together he still doesnt work.
Puan 0
1 Yorum:
tarafından
Yorum Ekle
Hello, thank you very much for your help, but the problem is that when I opened the gearbox one of them came loose and I don't know where to put it. I have included photographs with the gear
Puan 0
1 Yorum:
I don't see the picture you sent. Maybe you should check—there's no gear image.
tarafından
Yorum Ekle
I have same problem and wonder where you obtained the replacement gears
Puan 0
1 Yorum:
I modified some but on Amazon there is an assortment of platic gears for toys. There are like 75 in a pack for under 8 USD
tarafından
Yorum Ekle
Yanıtını ekle
Dillon Bieber sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 3,027
