Ana içeriğe geç
The Canon EOS Rebel T3, also known as the 1100D, is a continuation of Canon's entry-level line of DSLR cameras, the Rebel series. It features an 12.2 MP sensor and a DIGIC 4 image processor.
44 Soru Tümünü görüntüle
Blurred lens, blurred pictures
My pictures have started coming out blurry, especially close up.
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check the following:
  1. Autofocus might be switched off. On the left side of the lens barrel, there's a small switch with two positions, marked AF and MF. Make sure the switch is set to AF. Note that when the switch is set to AF, normally speaking the camera refuses to take a photo if it can't lock focus.
  2. Image Stabilization might be switched off. When you take pictures indoors without flash, shutter speed may be slow enough that any camera shake becomes visible as blur. The kit lens that comes with this camera has IS built in. It doesn't do miracles, but pics with shutter speeds as slow as 1/8 (depends a bit on how many coffees you had) come out sharp without having to use a tripod. The IS is controlled by a switch on the lens barrel, next to the AF switch. Make sure it is set to ON.
Bu yanıt yardımcı oldu mu?
Puan 7
4 Comments:
It seems like the lens is broke it won't focus it's in image stab picture won't take unless in manual or I make sure it's focused
tarafından
I have a similar problem, I've tried all those options and even replace the lens but I still have blurry pictures. Seem the problem is coming from the camera.
tarafından
i have tryt o change to AF mode but it dont let me to take picture and keep showing BUSY!!! but when i change to MF mode it can works just cant get a clear pic
tarafından
Thank you! You fixed my problem ??
tarafından
Yorum Ekle
Is the auto focus turned off or the shutter speed preset to a slower speed than it needs to be (auto mode is off) or is the aperture preset?
Puan 0
1 Yorum:
Need help to set my camera so the pictures are not bluery
tarafından
Yorum Ekle
Hi, I have Canon eos 100d and everything was great till yesterday. In one section of a picture it is blury, and I am afraid that I damaged the lenses or something. What that could be?
Puan 0
Yorum Ekle
I have a Rebel T5 and can attest to the blurred image issue. I bought the camera when in university several years ago and was disappointed with its focusing capabilities. The camera performs poorly in anything that isn't broad daylight. Even when using a tripod, the timer, and adjusting the various camera settings, it didn't change. I find my images retain a soft edge when blown up to maximum size on the computer. I just don't think this particular model with the supplied lens is capable of producing a crisp image. That said, I'm burned by the experience and likely won't ever buy a DSLR again. It's not worth the hassle.
Puan 0
Yorum Ekle
I have canon EOS r, when I am trying to take a video or a picture the screen is showing blur. Nothing is clearly visible. I had checked my AF ,shutter speed, lens everything is fine .Can you please tell me why my pictures are appearing blur.
Puan 0
Yorum Ekle
Yanıtını ekle
michelle jones sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 144
Son 30 gün: 792
Her zaman: 50,990
