Ana içeriğe geç
Repair information for standalone freezers.
197 Soru Tümünü görüntüle
Why is my upright freezer leaking a "lot" of water from underneath?
My upright freezer is leaking a "lot" of water from the bottom! I don't think it is quite as cold as it usually is, but the food is still frozen. I hear a noise, but not sure if it is just a fan, or motor, or compressor. Don't think it sounds as it normally does. The water covered my entire garage floor...I can feel cool air coming out the vents on the inside, but the foggy stuff isn't circulating.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Cause 1
Clogged or Freezing Defrost Drain
During the freezer’s defrost cycle, the defrost water exits through the defrost drain. Sometimes, the defrost water can freeze over the drain. If the defrost drain is clogged with ice, the defrost water will overflow the drain and leak from the bottom of the freezer. To thaw the ice inside the defrost drain, use a turkey baster and hot water to flush the drain. If your defrost drain freezes regularly, consider installing a drain heater to melt the ice.
Where do you live an how cold is it in your garage?
Bu yanıt yardımcı oldu mu?
Puan 8
1 Yorum:
It is not in garage but in the basement, which is set at 68F. Ontario, Canada
tarafından
Yorum Ekle
my door was lift open by mistake none it will not freeze all the can you please help.
Puan 0
2 Yorum:
my freezer leaks from underneath ive told my new landlord but he just says thats what happens its about 6 yrs old it never did that before
tarafından
my freezer is leaking from bottom my new landlord says its ok thats what happens but it has never done that before its 6 years old
tarafından
Yorum Ekle
Yanıtını ekle
gracie1rda sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 117
Son 30 gün: 582
Her zaman: 52,912
