Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Soru Tümünü görüntüle
No USB Connection after I broke little SMD element near connector #4!
I can neither charge the iPhone nor connect it to iTunes. Nothing happens when the phone is connected to a USB/charging cable. If the iPhone is off, connecting a cable turn it on.
It seems I broke a little SMD element near connector4 of the logic board when I disconnected this connector with a screwdriver!!!
Does anybody know what type of SMD element that is and where I can buy it? It is so little that I lost it on my table and never find that part again!
See picture:
Update
I am having this problem, but I just checked my board and that SMD looks perfectly intact. What else could be? The connector 4 is firmly attached as well...
Bu iyi bir soru mu?
Puan 1
1 Yorum
If you still have the mentioned SMD coil and your iPhone starts up when connected with usb charger it's another problem. Start you own question!
The coil filters the USB data lines. Maybe your line is broken on another point?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I found an answer myself:
This element is coil!
Connect like this:
http://forum.gsmhosting.com/vbb/f631/iph...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
It was the "NOISE FILTER COM MODE 90 OHM SMD" -> Digikey part number: P14216CT-ND. http://forum.gsmhosting.com/vbb/f631/iph... - Data Sheet here: http://industrial.panasonic.com/www-data... (Common mode Noise Filters, Noise reduction of high-speed data lines such as USB,
LVDS, and HDMI lines)
tarafından
Yorum Ekle
Yanıtını ekle
James Bond sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 13,035
