Ana içeriğe geç
Mazda Protegé'nin altıncı nesli; Mazda Familia ve Mazda 323 olarak da bilinir. Beş kapılı fastback modeli Familia Astina veya 323F olarak biliniyordu.
emergency brake not working
My 1993 Mazda Protege emergency brake does not work and I need to fix it as soon as possible and I don't know where to start. Can anyone help??
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@karahunter52 could be as simple as needing an adjustment to as tough as replacing the cable. Let us know if it has reaR disk or drum and also if you have any resistance when you pull the lever.
Resim
Resim
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
My back brakes are drum brakes.
tarafından
@karahunter52 did you check the adjustment as well as the cable? Check on here about how to adjust the brakes and on here for the replacement.
tarafından
Yorum Ekle
Most ebrake problem come from years of neglect. Lets face it unless you have a standard transmission you don't use your ebrake then you when need it for a safety certificate so you can sell or buy a car depending on where you are and the rush is on to fix it. Start by removing the rear wheels and the brake drums then focus on where the brake cable comes through and put some sort of penetrating oil in the cable and then start trying to move the cable in and out of the case that's covering it. this is the point were most cables seize. it my be easier just to replace the cable as the area that seizes usually becomes week and can break. If your one who does use you ebrake and its not seized then the cable has probably broken somewhere and will need to be replaced . There is also the chance if your lucky that it just needs to be adjusted this is done in the inside of the car at the base of the parking brake lever. Mike (oldturkey03)has once again provided great manuals to help locate everything . Hope this helps
Puan 2
Yorum Ekle
Yanıtını ekle
Kara Hunter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 2,328
