Ana içeriğe geç
2013 yılında piyasaya sürülen, UN60FH6003FXZA model numaralı Samsung 60" LED HD TV için cihaz ve onarım bilgileri.
Back light dark on top
Dark the top is black
Bu iyi bir soru mu?
Puan 2
6 Yorum
@duba is it just darker or is it black? do you still see things on that part of the screen?
tarafından
I have the same problem, my screen is dark in the top.
tarafından
I have a similar problem but I have no image or sound it just blinks now on and off and the top of the tv is darker then the bottom I replaced the power board and the main board and still no fix need any tips!
tarafından
I have the same problem. it started gradually getting worse now to the point the top is virtually un-viewable with the darkest at the top fading back to normal at the bottom. there is three cards in the back, has to be one of them i would think.
tarafından
@georgesl not necessarily. Could be the LED strip that makes up your backlight. Repairable by disassembling the panel itself and hopefully getting an LED replacement
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@dube @lintaum this is most likely caused by a failed backlight. Could be the power board, the LCD or the inverter circuitry. This is a vague answer due to the fact that we do not have all the information.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Portia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 4,639
