Ana içeriğe geç
Samsung tarafından 2015 başlarında piyasaya sürülen bir Android akıllı telefon olan Galaxy E7 için onarım rehberleri ve destek. 5,5 inç Super AMOLED 720 x 1280 ekran, dört çekirdekli 1,2 GHz Snapdragon 410 işlemci ve 2 GB RAM özelliklerine sahiptir.
Outer Glass only Replacement.
Is there anybody who have replaced only the glass for the SAMSUNG GALAXY E7 (SM-E700H)
I have been looking for videos and tutorials, and havent been able to find one.
Please advice.
Thanks
Marvin Méndez B
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I performed a search on Youtube for relevant videos for the outer glass. Most results showed the replacement of the full LCD assembly. I cross referenced the release date of the E7 with the S6, which showed they were released two months apart. If the manufacturing process is similar then the procedure/technique should be consistent for both phones.
I did find the Front Outer Lens Glass Screen on Amazon, so I ran the search on Youtube for the S6 instead.
I reviewed, Samsung Galaxy S6 Disassembly - Glass Removal - Glass Only Replacement, which should be similar for the E7. Additionally, I thought, Galaxy S4 JUST THE GLASS Screen Repair BEST Video was also helpful, though it is for the S4, which was released two years earlier than the S6 and E7. The technique and correct tools used is what makes the removal process successful.
With the availability of the part to change the glass, it should be possible, but please take into consideration that since there is limited documentation, the possibility of the adhesive being stronger, as stated above, may also be possible as well.
If you decide to use these videos mentioned as a guide, perhaps, you could record the process with video or images to provide documentation for this model for others who may have the same desire.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Unfortunately Samsung made the new s7 edge to be difficulty to repair when it comes to doing glass only repair. They have used thinner LCD and stronger adhesive to bond the two together.
Puan 1
2 Yorum:
But I am confused here, E7 I think is not S7 Edge?
tarafından
I do apologize I read it wrong with the E7 thinking you meant Edge 7 which some people call it. I did look up that model and it looks like a flat screen which the glass only repair will be easy once you open and see how the LCD is bonded together. You can fallow any galaxy S5, S6 removal process once you open the back cover and see how the logic board and compotes are laid out and you can compare from there and find a video on youtube to do the process.
tarafından
Yorum Ekle
Yanıtını ekle
marvmen21 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 2,399
