Ana içeriğe geç
The Xiaomi Mi 4 is the fourth generation of the Mi line of smartphones produced by the Xiaomi Technology Company. It comprises of the latest technology that all phone companies have to offer in the world.
64 Soru Tümünü görüntüle
Phone not starting Mi logo flashing on and off
hey, i brought my Mi4 less than one year back. Last month it suddenly stopped charging so i went to the service center and they changed the sub board. ever since then my cameras focus is gone and the phone is heating up and the phone goes switched off and the logo startes to flash on and off for a long tym... and late it switches on by itself.
it is really frustrating.
Pls help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
7 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It's a very common and stupid bug by Xiomi Mi.
It can be solved easily but u need to have more patience (mooorreee)
Even if you connect the charger, you wont be able to see any sign of charging and continues blink (kind of boot loop). I am sure this should be the problem for you (not only you, more than a millions)
1. Connect the phone with a charger, you may or may not see any sign of charging
2. Wait for at least 15 minutes and max of 45 minutes until you notice some sign of charging
3. Never disconnect the charger even for a single second while doing it
4. After a good amount time you get any of the below,
5. Phone booted without any issue :-)
6. If not use Power + Vol Up button to boot into recovery mode wipe all,
7. I not Vol + Down to fast boot. Keep charging until u see any sign of charging.
8. Try with another charger if it didn't
Let me know whatever result u get, I will give u the good solution, but don't forget to reply
Cheers,
NallasivanG
https://twitter.com/NallasivanG
Bu yanıt yardımcı oldu mu?
Puan 1
6 Comments:
My Redmi Note 6 Pro has been switching on and off in a continuous loop. The MI logo appears for a few seconds and the screen goes black. Afterwards, the whole process keeps on repeating. I tried to use the Vol uP+Power button, but the problem keeps persisting. I think the power button of my phone is automated. Have you encountered this problem?
tarafından
I am facing same issue. Can anyone help in lockdown we cannot even go and get it fixed.
tarafından
I have the same issue as well for my Redmi Note 6 pro. any suggestion?
tarafından
i have also the same problem, when i try to boot the phone the mi logo will appear on screen just for some second turned off ..
i had also wiped all the data using power + volume up button,
while formatting the mobile phone, the formatting process percentage showing on the screen . eg 95$ completed.
but it show that the formatting is completed when it reached the 3% percentage.
What the problem i am thinking :
The internal memory of mobile phone has been damaged.
tarafından
My mi note 5 after a long press in the power button shows mi logo and after a few seconds it’s shut down again plz help
tarafından
1 tane daha yorum göster
Yorum Ekle
Go and check this article this article will help you in solving this problem.
Puan 1
Yorum Ekle
Try to Flash the device using Fastboot files
Firmware for your device
Use Mi Fastboot tool as flasher
and check the steps on xiaomo official website
Puan 0
3 Comments:
My MI note 4 screen is suddenly showing black with only Mi flashing & only it taking for charging. Kindly suggest what to d as its is lockdown so no repair shop open. Thank you.
tarafından
@nallasivan i have a zte blade xmax (z983) and when i plug in my charger it shows that its charging then it stops charging and shuts off again and it continues to do that so should i follow your steps (my phone is shut all the way off for charging) what do i do
tarafından
The same thing happened to me too yesterday. Why did such odd behavior start to appear on the same date? There must be a strong reason for this. It's not consequence.
tarafından
Yorum Ekle
I did the flash process in my redmi 2 prime phone, when I flashing the phone it restart at the end of the flashing process and the same issue arises, “Phone not opening and flashing MI logo again and again”.
Kindly help me out!!
Puan 0
Yorum Ekle
My phone are stuck in mi logo what can I do?
Puan 0
2 Comments:
Also me alway Mi logo affear on the creen...sometime fastrebot then after a minute go back again to MI logo not open the phone
tarafından
Plz.help me....whay can iso
tarafından
Yorum Ekle
You can try flash boot device for your error and you can also visit our site to know about the odin tool, Thanks
Puan 0
2 Comments:
Mine too i reboot my phone but after that it cannot open anymore i tried to charge it but no sign of charging nd the logo keep on flashing on nd off
tarafından
Hi, any solution after the logo keep on flashing on nd off ?
tarafından
Yorum Ekle
My mi max prime won't start up?
Puan 0
Yorum Ekle
Yanıtını ekle
Chippy Balagopal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 66
Son 30 gün: 352
Her zaman: 30,343
