Ana içeriğe geç
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
20 Soru Tümünü görüntüle
iSight camera not working
Hello all,
I have an inconvenient problem the Macbook Air 11 Early 2015 iSight camera seems not to work when I use FaceTime all I get is a black screen with a blinking LED by the camera.
i did a system reset but nothing happened
I need a final solution
Some answers talk about the Cable connected between the iSight camera and logic board is not connected
Please help!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
This machine may still be under warranty or if it's just out Apple may allow you to add AppleCare. What's the purchase date? If you don't remember go here and input your serial number. If you registered it it my show if it is still covered: https://checkcoverage.apple.com
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
En Yararlı Yanıt
Using this IFIXIT guide: MacBook Air 11" Early 2015 Display Replacement Follow the first group of steps (Steps 1 thru 3). Then jump down to Step 7 making sure its connected.
If you see any damage due to dampness you may need to clean the logic board and connector with a moist cotton swab with a good quality isopropyl alcohol (85% or better).
If that doesn't fix it I suspect your iSight camera is bad and that will require replacing the full lid assembly unless you can find someone with the needed skills and parts to replace the camera unit from a junker system.
Puan 3
Yorum Ekle
How was this solved? My camera is not working, it is showing the green blinker only.
Puan 0
Yorum Ekle
Yanıtını ekle
Mahmoud sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 2,116
