Ana içeriğe geç
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Soru Tümünü görüntüle
Need help identifing faulty componet on full start up failer.
iMac 20.2 Model A1174 2006 last 4 of...
I just installed a replacement power supply on the iMac 20. It's doing the same thing it was doing as before I replaced the original power supply. It powers up then begins to load the OS. After about 20 - 35 sec. The iMac then just power off completely. It will continue to do the same thing after it is powered up again. Turns on, partial OS loading, then powers off. So I'm wondering if anyone have seen this before and could direct me to the faulty part. From what I saw on you-tube and what people posted, I really taught the power supply was faulty. I would appreciate any help anyone can give me. Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Give me a day or two on this one. I have a 2007 on the bench now with the exact same issue. We've tried three power supplies. Changed video cards. Next the plan is to use a heat gun on the CPU. Will update you if I can find the problem.
tarafından
Any luck? I would love to hear that you found a solution for this issue. Thanks.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try booting with an external drive. I usually keep a lightweight linux bootable flash drive around to boot off.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Serg sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 85
