Ana içeriğe geç
Çift mikrofon ve 802.11ac Wi-Fi kablosuz bağlantı özelliğine sahip daha büyük Apple MacBook Air dizüstü bilgisayarı.
MacBook Air SMC problem
Hi all,
I have a problem with my macbook air 6,2.
The first issue was the computer did't turned on.
The SMC reset and regular things did't helped.
I took down the bottom case, and plugged out the battery cable. After this when I plugged in the charger, the computer is turned on immediately.
I took back the case, and restarted the computer, the computer was dead as before.
I ran a hardware diagnostic test and got the PPT001 (battery), PFM001 (SMC) and NDC001 (webcam - this one is weird because I can use the camera).
So right now I can turn on the computer without the bottom case, but the fans are running high etc.
The power adapter led is not lighting, and when I push the shift + ctrl + alt the computer is turned off immediately.
Anyone have an idea what can I do with this SMC issue?
Bu iyi bir soru mu?
Puan 3
3 Yorum
Hi,
I have exactly same issue with my Macbook Air 13" 2014.
How do you repair it?
tarafından Paylaş
First issue was fixed without any intervention. I just waited few days..
The secound issue was the SSD, so I just replaced it. Maybe the first issue was an SSD issue as well.
tarafından Paylaş
@wntsmk I have the exactly same issue with macbook pro mid 2012 ....what I have to do please help me
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yeah it was my first idea. Few days later the computer turned on and worked fine.
But another few days later started to do a weird things, for example restart without any reason. After one of the restart the OS never started again. I checked the SSD with the install system, and haven't seen it, so I ordered a new SSD, and now everything is fine.
Maybe the first issue reason also was the SSD.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
ok i'm happy your problem is solved.
tarafından Paylaş
Yorum Ekle
Guessing right now but, what if you replace the EFI BIOS chip?
Puan 0
Yorum Ekle
Hello, I can recommend a company in Turkey that can repair this malfunction. Prices are reasonable and experts in the repair of the MacBook https://kaptanbilgisayar.com.tr/atasehir...
Puan 0
Yorum Ekle
Yanıtını ekle
wntsmk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 7,502
