Ana içeriğe geç
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
note 4 screen not turning on but buttons still light up
After opening up my note 4 and adjusting the gps antenna on it when i put it back together the screen no longer turns on but the buttons still lights up indicating that power is running to it can you guys give me a brief idea of what component i need to check out to fix this?
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The LCD cable plugs in behind the logic board. It probably went loose if you lifted up the logic board. You simply just need to plug it back in. It's a bit tricky to do.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
do u have a picture of which ones?
tarafından
Check step 6 of this guide. You should be able to plug in the two cables. I think one is for the S-Pen and the other is for the digitizer + lcd.
Samsung Galaxy Note 4 Display Assembly Replacement
tarafından
Yorum Ekle
Yanıtını ekle
baconlover53 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 4,390
