Ana içeriğe geç
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
35 Soru Tümünü görüntüle
The light on the drone blinks green then turns red
After I had an accident in which my Parrot Bebop fell about 75 feet, I could not turn the drone on again. When I pressed the rear light to start the drone, first the light blinked green and then turned red.
I at first thought the problem was one motor that had been damaged. I replaced the motor in question, but the light still blinked green and turned red.
Eventually, I took the drone removing the motors, camera, and gps until there was only the motherboard connected to the battery. Now, I still get the same response. When I press the turn on button the light blinks green and then turns red.
Do you have any suggestions for repairing this Parrot Bebop?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum:
Have you found a solution? I have the same problem and am unable to find a cure anywhere.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
This has to do with either
Disconnected motor
Or disconnected GPS board
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
i am working on mine right now and it seems that the motor drivers have an open ground or negative, when powering on the motors should activate a few short pulses. my drone does not, but you know guys it would be a !&&* of a lot easier if they would supply a circuit diagram
Puan 0
1 Yorum:
Okay, so I took the drone completely apart and searched for any connections that might be questionable. I did not find any obvious issues, just for being able to say that I did something I reflowed the power connections to the mainboard and reassembled the drone. It is working again. Very nice construction of the mainboard. I would say, it's probably 5 layers thick.
tarafından
Yorum Ekle
Yanıtını ekle
cmitc sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 2,912
