Ana içeriğe geç
The Asus VivoBook X202E is a small laptop released in late 2012. It has an 11.6-inch touchscreen display and a 3rd-generation Intel processor inside.
23 Soru Tümünü görüntüle
Strange circles while powering up and in log-on screen, no log in
Hi,
when I power up my ASUS X202E I see strange circles and when Windows (10) asks my log in password I can't reach the input-field because the PC seems to be busy.
Could this be the touch-screen being defective?
Awaiting someone's reply,
Kind regards,
Leo
Updaten (15-06-16)
Hi everybody,
The problem is 'solved' I seem to have a short-circuit in the signal cable of the touch-screen.
I disconnected the cable on connector J3902 of the IO board and the PC was accessible again.
The only problem is no touch-screen anymore.
Kind regards,
Leo.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
Same problem: during startup strange circles/bubbles showing up and flashing lines going random over the screen. Also a mouse pointer ( arrow, precision point or hand) shows up and moving. if a icon is opened, the text goes up and down and zooms in and out. really impossible to work. Updated the drivers to latest version for W10 but didn't help. Disabled and deleted the touchscreen drivers and the problems disappears and one can work with the laptop but without touchscreen. Touchscreen however does re-install itself if the PC is switched off. Have to disconnect the cable as described above by Leo. Looking for the service manual.
tarafından
By disconnecting the cable, the touchscreen is disconnected and the problem completely disappeared. Although without the touchscreen, the laptop can be used again and doesn´t need to be replaced by a complete new one. Thanks Leo.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
This is strange, I would try booting into safe mode (you can do this buy force shutoff 3-5 time when booting, it will start into a repair mode at some point and from there you can boot into safe mode) and see if you can login if so I would run a virus scan reall quick... And you can also uninstall the touch drivers and see if that helps...
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I have ran several virus scanners and nothing has been found. It's not a virus. Just de-installing the touchscreen drivers doesn't help because next time you startup the driver will be installed automatically.
tarafından
By disconnecting the cable to the touchscreen, it´s not detected any more during start-up and due to that the driver isn't reinstalled. This solved the problem. The laptop is now normally functioning but without a touchscreen. still using the ordinary mouse or touch-path, is cheaper than replacing the touchscreen !.
tarafından
Yorum Ekle
Thank you Leo, your solution completely solved the problem.
Puan 0
Yorum Ekle
Yanıtını ekle
Leo Blokpoel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 428
